Originally posted by: dug777
afaik these babies are xpensive as...assuming ur r referring 2 those ones that heat water on demand...much more efficent 2 have a hot water heater that heats a medium sized tank with good insulation, but depnds on ur daily usage patternsa i guess-wait this would still b better if u coul program teh heat times 2 suit when u use it...
holy hell batman, i think we need a spelling lesson.
MIKE
MIKE
or an analysis of how much teh poster has had 2drink 2nite...
Originally posted by: flot
As usual, no one knows what they are talking about. Lol.
They come in gas and electric varieties.
You can get "point of use" tankless water heaters, for instance, would install under your kitchen sink and give you hot water right there, but you can also get whole house ones.
I have done basic research into the whole house electic ones, and a neighbor just had one installed. They work by detecting water flow through the pipes - so when you turn your hot water on, it takes the unit a fraction of a second to notice the water movement, and then it instantly kicks on the heater.
You size the unit (ie how expensive it is) based on your lowest INCOMING water temperature. For instance, here in South Florida, our incoming water temp is probably never lower than say 60 degrees. So you find the unit that can offer you a temperature raise of, say, 50 degrees. That unit will be able to put out 110 degree water NONSTOP ALL DAY LONG. As soon as you stop using it, the heater turns off. As soon as you start again, the heater kicks back in.
If you live in an area where the incoming water temp can get very cold - one of this units is probably impractical. Even in south florida (if I recall correctly) the units need a direct 60-80 amp electrical feed. So they use a ton of electricity - but they use it all at once.
As for flow rates, I think most of the better models can keep up with 2 uses at once but probably not more than that - of course depends on the flow rate of your showerhead etc. They rate the units in temperature raise at a specific flow rate.
My neighbor's was about $500 for the unit and probably about that much for the install (high amp electric plus water lines plus removal of old heater). It hangs on the wall and is about the size of a phone book.
I have a small house in s. florida, so for me it is perfect - my incoming water temp isn't very cold, my water needs are low, and more importantly - I can regain all that space that was previously taken up by the water heater and its plumbing.
No way you can run two showers unless you have water saving shower heads. Personally, I like a lot of water pressure. My water is either hard or soft don't know which but it makes getting soap off difficult. I would hate lower water pressure.
For the amount of water the tankless heaters can output per minute, they did not meet my needs. I am sure they meet a lot of people's needs just not mine.
