taking pictures vertically should be banned
Originally posted by: lnguyen
acdsee will also read the orientation bit to auto rotate.
I use ACDSee 3.1 (before the bloatware) to view the pics (taking over for XP Picture and Fax viewer default)... and it doesn't auto-rotate. You're saying the newer versions do this ?
Why would you use Photoshop to rotate them? You have to resave them in a lossy format.
Rotating pictures is the last thing I care about.
1) EXIF data should be standard on matter what kind of camera. I hate this BS that it is different from every camera.
2) Widescreen monitors suck. Most my pictures are vertical. I don't need even more space to be wasted on a black screen.
Originally posted by: Phil
Originally posted by: VTHodge
Originally posted by: Mark R
use the windows image preview that comes with xp, just browse through them and rotate with the little buttons at the bottom, hellofalotfaster than photoshop
And a lot less quality.
What??
Windows is not going to cause any quality drop just by rotating a picture. I use this feature and it is really helpful and fast.
He probably means this.
Edit: That picture is 320x240.
Wow, I've never gotten that. I guess I take it back.
