What I usually do for something like this is use the "Diskwriter" plug-in in the "output" section of the preferences menu in Winamp. This converts the mp3 to wav. Then I use a wav editor to cut out the section I want and save it as a file. Then you can delete the rest of the wav file.
Look for a copy of "goldwave".... it is great (allows you to string lots of waves or mp3's into one wav file). Winamp should have worked for you also though...?
