- Mar 5, 2001
- 18,256
- 68
- 86
Does the union decide where the money is parked or did the state/municipal gov?
That will make a difference. If the gov. did not "borrow" or knowingly underfund the plan. The members should take the hit if they were in control. If the state was in control. The taxpayer/voter is on the hook.
It doesn't matter who was in control, the amounts were over-promised.
It doesn't matter who was in charge of the money, the results are the same. Most pensions use the long-term return for stocks from the last X years and say that the portfolio will grow at about the same rate. However, it doesn't take into account dips, downturns, or the simple fact that you have an asset-liability mismatch. You are guaranteeing an 8% return yet you cannot guaranty an equity return. If you want to guaranty something you buy a bond and even then you still have to determine potential losses.
If you don't change how much money goes in and you are capped at how much your return is then you will end up with an under-funding no matter what. It doesn't matter who manages it.
As far as private equity being better or worse, on average PE/HFs don't beat the benchmarks or the industry average, it's a simple bell curve. People like Ray Dallio or Warren Buffet are enigmas, just the skinny part of the distribution. Most cluster on in the center and once you eliminate fees, are probably no better than buying a bond or equity index.
They want to repeat Harvard's success. How do you do that? You spend money on management. You can't entice these guys with crappy pensions or guaranteed employment, they need money, the same money they'd make managing money elsewhere.
Thus, you pay up hoping to increase your return.
However, the most simple answer is to either force the pensioners to contribute more or to take less. But we can't do that...
