T40 owners, 802.11g solution from IBM is close!
OldSpooky
356
Found this linked on the IBM T40 forum:
IBM product announcement
September 8th is the planned introduction date. Price is expected to be $99 for the a/g card (well, a/b/g, but I call it an a/g because g implies b compatibility).
I was kinda hoping they would release an 802.11g only card for $50 or so. Maybe they will.
nanyangview
Banned
Jun 11, 2002
1,010
good to know that...well done IBM
USD$99 is not that bad at all.
btw..is there a official IBM or Third party t40 forums?
eriqesque
704
In the notes section it states:
ThinkPad models with integrated 802.11a/b functionality may not be upgraded with the 11a/b/g Wireless LAN Mini PCI Adapter.
I can't figure out why that would be.
mocca
203
May be they refer to the security screws that they put on T40 model that have dual a/b wireless miniPCI. Other then that, everything is identical between the model with dual wireless and the b only. It is kind of silly of IBM to put the security screw on the one with 802.11a/b miniPCI since the TR7 screwdriver can be obtained easily from many local hardware or computer store.
Mocca
eriqesque
704
Mocca
So then it actually can be done?
mocca
203
If you refer to removing of the palmrest and change the miniPCI wireless card (physically), then yes and easily if you are familiar with removing/assebly electronic part. The compatibility IMO should not be a problem if it can be used with other regular T40 models (i.e., they all have physicaly the same connector, and share the same MB design.
Mocca
RichieZ
6,551
40
I ordred this mini-pci card with my new laptop (X31) but its now backordred for 8 weeks! I'll let you guys know how it works and how easy it is to install when i finally get it
