Originally posted by: Fiveohhh
Just got back from Best Buy and after spending 20 minutes opening up 6 dvds(for$60 no less😀) I was going to check out the T2 in HD, and wondering if its possible to watch it w/o the installing the interactual player I thought since it was
wm9 encoded wmp9 would play it😛
If i remember correctly the requirements were all crazy for the extra stuff on the DVD's. My friend has them and he thought they were joking about the requirements when he bought it.
Originally posted by: JonnyBlaze
you dont need to install the player.
there is a .exe file on the dvd you need to execute then you can just play the files in wmp.
JB
its dvdrun.exe the wmv files are in \common\win\lang\en\t2x\esource
JBlaze
