Shadow Conception
The parts just came in the mail, and I built the PC. The specs are below:
Gigabyte GA-EP45-UD3P Mobo
FSP Group SAGA+ 450R 450W ATX12V PSU
Intel Core 2 Quad Q8200 2.33GHz
2GB Crucial 800MHz RAM
eVGA GeForce 9800GT
So, when I press the power button, the system fans come on and work fine. The motherboard's LED's come on. However, nothing else seems to be getting power. The graphics card, CPU + CPU fan, DVD drive, and hard drives seem to be getting no power at all. There is no display on the screen (although the monitor is getting signal). After turning on the computer, and then turning it back off, the CPU fan seems to give a feeble attempt at running, but nothing from then on.
Everything seems to be connected fine, including the 24-pin ATX socket. However, one thing I was not able to plug in was some ATX 2x4 pin connector. My power supply did not have the right connector. I think this may be the reason why nothing except the CPU fans are getting power.
Could this be the problem? Does an adapter exist that would help me out?
Edit: So I plugged in a 2x2 connector, leaving a 4 pins on the ATX connector free. System POSTs fine, all the components work. Should I get an adapter for the rest of the 4 pins?
eVGA GeForce 9800GT
