Thing is when I tried going to 3.125 Ghz last night, I had a green CPU overvoltage light turn on in addition to a memory overvoltage light (also green), where there are green/yellow/red levels. Should these lights be on at max clock?
I mean it all seems like a massive sensitivity challenge, I assume, where a given component can be pushed to some maximum given everything else is set low, and then, given these maximums, find some optimal point as a combination of some levels sub-max such that the system is pushed as far as possible while still remaining safe.
However, I'm not sure if this is true or what the ACTUAL process is. "Just fiddle with stuff" is not how one reaches an optimal point.
