"System" process uses 99% of CPU...
Arcadio
5,637
24
What could be the problem? The System process uses 99% of CPU. I thought a format/reintsall would fix it, but it is still occurring after restoring (using the HP manufacturer full restore option).
lxskllr
59,465
9,979
System Idle Process? That's telling you how much your computer *isn't* being used. If it's at 99%, then you have 1% cpu activity.
Arcadio
5,637
24
lol..no that's not it. It is a process called System. The computer is very slow because it is running full throttle all the time. It is definitely not the System Idle Process.
lxskllr
59,465
9,979
Oh, ok. I didn't remember seeing that, but it's here on my work machine. What O/S are you on? I'll look into it some when I get on my home computer.
Billb2
3,035
70
86
The "System" process runs a lot of other things.
Download Process Explorer from Microsoft and investigate.
Roguestar
6,045
It's probably just running benign background tasks. It may say that "system" has 99 percent usage, but on the task manager graphs is your CPU actually at 99% utilization?
Blain
Maybe you picked up a bug from some of the "questionable sites" you've visited.
:roll:
Mr Fox
876
It's The Canal Zone Clap... you got Drip Dick.. it is embedded in your Restore Points.
FFFFFFFormat !!
Arcadio
5,637
24
It's running all the time. The computer is running super slow because of it. The whole format/reinstall took 3 times longer than usual thanks to whatever is causing it.
Raduque
13,140
138
There's something else wrong here. HP/Compaq's restore process occurs outside of windows.
Try a different hard drive and a clean install of windows, see if it still shows up.
JackMDS
29,545
422
No need to Just Push Air when the actual data can easily obtained.
Download this Free utility (No need to install just run the unzipped exe file), http://technet.microsoft.com/e...nternals/bb896653.aspx
Look at the View Menu to make sure that you check all the info that you need.
Pairing it with this might further help,
http://technet.microsoft.com/e...nternals/bb896645.aspx
If you want to find which port are opened and listening to what, http://technet.microsoft.com/e...nternals/bb897437.aspx
coolpurplefan
1,243
If you want to erase everything next time you do a format, then follow the instructions on the screen during the install to delete then re-create the primary partition.
Then you can make a list of all the BIOS settings and clear your CMOS. (You can google "clear CMOS".)
BigPoppa
Most often when I see this, its actually caused by a driver not loading/performing properly when you have bad hardware. The last occurance was because of faulty USB ports.
