system pre-build, please check
ShadowBlade
i havent ordered anything yet and wont for about a week, i will be using this computer for gaming, music, movies, internet....the works
Ordering in about a week (hopefully):
AMD Athlon 64 3000+ s939
CHAINTECH NVIDIA nForce4 Chipset Motherboard
(re-using existing parts for rest (for now))
EDITED AGAIN x2:
Ordering when i get more money:
Sapphire ATI Radeon 9600XT (256MB DDR)
2x512MB Corsair PC3200 RAM
Antec 430W Power Supply
[at least one] Maxtor 250GB SATA Hard Drive
Cooler Master Hyper 48 Heat Pipe Cooler
Sunon 120mm fan, 108CFM
2x Sunon 80mm fan, 84.1CFM
3D Edge Fan Kit
Links:
CPU (newegg link, am buying at ZZF)
mobo
video card
ram
power supply
hard drive
cpu cooler (will try to find at newegg or ZZF)
fan 1
fan 2
slot cooler
That rig screams rice, why bother so much with the OC and then put such a subpar video card in? Save what you're spending on the fans, hsf & video card cooler and monster PSU and get value ram instead of that crap, then see what flavor of 6x00 you have money for. Jesus, that's like a $10,000 Civic with $20,000 worth of additional mods and the same 100 base horsepower... Please don't tell me you were planning on case lights too 🙁
What are you going to be using that computer for? If you're going to game on that machine, you should spend a bit more for a PCI-E motherboard and 6600GT. If you don't, there's no point in getting a $140 video card, because a cheap 9200 or even MX440 will be good enough.
My case already has lights 😉
my price range is very tight, otherwise, i would go PCI-E
ill just wait til amd boards have ddr2, by that time my budget wont be so tight
PCI-E boards aren't expensive
Why the hell would you get a 2.0 SLI PSU for that system? You don't even have a PCI-e MB. The 2.0 means it's PCI-e ready and you damn sure don't need 2 PCI-e connectors.
