- Dec 4, 2003
- 23
- 0
- 0
So I checked my system stability recently with Prime95, and it fails any and all tests in 4 minutes or less. I've run MemTest on my RAM, and found that one stick was faulty. So after taking it out and running Prime95 again, I still have the same instability problem. I took everything out of my computer, except for a stick of RAM, CPU, HDD with my OS partition, and my GFX card... and it still isn't stable.
A friend told me that it might be because of fluctuations coming from my power source? My +5V node varies from 4.8V to 5V constantly. Like, it's always going back and forth every second or so. Is this within an acceptable range? It might make sense if this is the problem, cuz my CPU fan's RPM is constantly shifting between 3000 - 5000RPM. And 2 of my HDD's have died recently. Maybe it screwed my RAM too? I dunno... Help would be appreciated. Thanks. =^)
Also, if anyone knows how to recover HDDs, plz let me know. Apparently the information inside the drives is still intact, as are the partitions. But for some reason, WinXP doesn't recognize the file formats as NTFS, even tho boot-up programs like TestDisk see it as NTFS. However, WinXP DOES see the two partitions... I just can't do anything with them. They're just sitting there in "My Computer." =^\ But yeah, more important question is the PSU one ^_^ TYTY
-AznLemming
-AznLemming
