- Dec 12, 2010
- 1,915
- 354
- 136
I have been examining several recently noticed system error memory dumps which reveals three system errors showing up in Windows 10 v 1607 updated, Administrative Events, under Custom Views. No BSODs or any observerable faults in operation however but my research suggests others have had the errors but no one seems to have a solution. These errors are present despite ( or because of) a recent refresh install .
The first error says:
"The driver \Driver\WUDFRd failed to load for the device ACPI\PNP0A0A\2&daba3ff&1."
I have an ASUS board and tried to update the ACPI drivers in Device Manager but the response is that the disk has the latest files. I cannot ID the precise device and I cannot find the driver mentioned. There is some thought the error refers to an ASUS sensor app but that is not installed, so I am stuffed.
The second error says:
Log Name: System
Source: Microsoft-Windows-DistributedCOM
Date: 2/2/2017 5:26:03 PM
Event ID: 10016
Task Category: None
Level: Error
Keywords: Classic
User: SYSTEM
Computer: Trooper
Description:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}
and APPID
{F72671A9-012C-4725-9D2F-2A4D32D65169}
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
There are a few approaches to grabbing permission for the device referred in the APPID but they are complicated and my efforts have been useless. I wonder whether there is a quick and dirty approach ?
The third error says:
Log Name: Application
Source: SetupARService
Date: 2/2/2017 5:26:02 PM
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Trooper
Description:
Service cannot be started. System.NullReferenceException: Object reference not set to an instance of an object.
at SetupAfterRebootService.SetupARService.OnStart(String[] args)
at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)
I have not found much to suggest a solution to this ARService and would appreciate any assistance fixing these errors.
Log Name: System
Event ID: 10016
Task Category: None
Level: Error
Keywords: Classic
User: SYSTEM
Computer: Trooper
Description:
and APPID
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Trooper
Description:
