Hey,
About 7 months ago I put together a personal system equipped with the MSI K8N NEO4 Platinum SLI board (nForce4), 1GB DDR400 ram, 1.080 Tb of HD space (Irrelevant to my question, but I had to list it
), and a FX-55 processor coupled with the standard AMD heatsink that came with the processor.
I've been using this PC pretty consistantly for the full 7 months now, frequently to its limits, as I do a lot of visual art, graphic design, sound engineering, and music production. In some instances I have 3-4 Adobe applications open along with Macromedia Flash / Dreamweaver, 3D Studio Max, and I'm always accessing stock photography that can range anywhere from 5-40MB per compressed image.
While for the most part I've been impressed with this system - I've come to the conclusion it's not good enough, and that it's absolutely vital I drain every last penny I own to make it better (I'm ridiculously impatient and I have severe impulse control problems). Specifically, I am looking into cooling options to replace my current setup as my temperatures are running a bit hot and I want to OC.
Specifically, I'm looking at this:
http://www.tigerdirect.com/applications...details.asp?EdpNo=1645513&Sku=Z20-1105
My questions are:
1. Will system performance and stability degrade at all by me breaking the contact between the CPU and heatsink to install the above water cooling system? I think I remember reading a while ago that it's generally a bad idea to do so. Other people I'm talking to on IRC at the moment are saying its fine.
2. What should I clean the CPU with? (I was originally going to use a steel bristle SOS pad and dish-washing detergant, but I'm afraid that might be a tad too harsh.)
3. Being new to system cooling, are there any other cooling systems that I should know about within the price range of $200-$350 (My life savings), that are better than the Zalman Reserator1? I've heard of those crazy phase change systems - are there any respected ones within that price range?
Thanks for any help.
My questions are:
