System build help (semi-noob).
I just wanted to take a second to thank everyone for their help. I am going with the following:
AMD Athlon 64 3200+
Chaintech MB
2 of these RAM
6600GT
HDD
And I am going to use my current Antec ATX case and a buddy's Antec 400w ps. Also I will port over my CDD and FDD.
I have a 66/100 round cable for the CDD and a round cable for the FDD. Will I need a SATA cable for the HDD?
Anything else you can recommend?
Again, thanks all. You will definately hear how it all went. *crosses fingers*
Originally posted by: Hawkbit
Thanks for the advice on the guide reference. I agree that I don't need a $400 video card. The 6600GT at $250 is more than fine for WoW. But I do want the ram... 768 does not cut it for that game.
I have only dealt with Intel in the past. Yep, the benchmarks above prove that AMD are better performing chips, but I am looking for simplicity. How simple is AMD to use? The Intel system I built from scratch and did a winxppro install in less than 2 hours... what headaches am I going to get from AMD?
I sold my 3.6gHz Intel in favor of the 3500+ AMD that I have now. check my bench marks below to see what a lil 3500 can do.
Changed my mind on that Maxtor drive, going with the Seagate mentioned in the above post instead. Thanks again. 9.3 compared to 8.5 is significant I suppose.
You guys are awesome!
Yes, sorry, I'm replying so fast I'm not reading. Should be a great system.
If you can spend a little more, get an 8MB cache instead of 2MB on that HD. Don't sweat it though.
Awesome - I can't thank you enough for your help today. I am placing the order tonight, so expect raving reviews in the very near future!!
