BonzaiDuck
I've gone through much turmoil this year. It's almost comic that I had an accident with my best computer (I'm using it now) back in January 2021 -- zapping a USB port with a static charge when I reached to retrieve a vaping pen that was being charged on the port. Quickly, the USB controller on the motherboard went south, I replaced the board and did some other wonderful things, using the computer through July. I routine restart at that time caused the computer to hang and fail to post at boot-time. "NO! Another hardware problem!" I thought. I put the system aside hoping for time to troubleshoot and fix it with a minimum of work. I have a lot of burdens now -- two disabled people to care for, chores, sale of a house, all sorts of stuff. Finally got around to troubleshooting and quickly found that I'd left a non-bootable optical disc in the optical drive, causing the system to hang at boot time. There was nothing wrong. Nothing at all! As I've said -- "So STU-PID!"
Before any of this stuff happened, I'd noticed certain annoying behaviors of the machine when it comes out of hibernation. The system is on a household LAN with a server. I keep my Quicken financials on the server, backing it up to whatever (single one-at-a-time) system I'm using to access the file. My digital archive of PDF document scans is on the server, and I use both Kofax Paperport 14 and FileCenter DMS document management systems. The Kofax software seems sluggish on return from hibernate. MS Outlook has sluggish pop-up menus after return from hibernate. Sometimes, I notice Quicken seems slower. With impatience, I'll close everything down and reboot.
Somehow, I think this could be related to network settings that might need tweaking. It's not a hardware problem. I DO use Primo-Cache: I built the system with PC in mind. Maybe I need to tweak Primo, I can't say, and I've put out a similar message on the Romex Software user forum.
Any suggestions or thoughts? Is there something I should do with my Intel LAN driver for my motherboard? With Windows? Got any ideas? I could post this on "Networking" or "Software", but I can't be sure where the sluggish behavior comes from.
