Secondary system was working fine, then just shut down and now I can't get it to boot. During boot process, gets to "verifying DMI pool", then I get one long, continuous beep. The cpu fan will slow down with the beep, then speed up. This goes in cycles about 3 seconds apart. Tried reseating the video card, adjust the memory around, nothing helps. Power supply continues to run during this so I don't think that is a problem. Here are system specs:
K62-500
FIC VA-503+ mobo
128 mb PC-100 ram (2x64mb)
ATI Expert 2000 agp video
Soundblaster 64
BTC 52x cd rom
10gb hdd
Win ME
One other thing - it's in a piece of crap case. When looking at the guts from the side, the mobo leans a little toward the front of the case. I can't get it to sit straight, so it's a little loose inside, not sitting real solid. Maybe that's the problem??
K62-500
FIC VA-503+ mobo
Soundblaster 64
BTC 52x cd rom
10gb hdd
Win ME
