Synthetic oil vs regular oil...
DanTMWTMP
15,908
19
I heard that synthetic oil leaks/causes leaks in cars, but offers better performance, whereas regular engine oil will do a decent job and is better at longevity.
I know someone @ work who just put in mobil 1 in his car, and he's been raving about it ever since. Mobil 1 = synthetic yes? (i think?).
So I've been thinking, should I put Mobil 1 on my car, or do you guys have other recommendations?
So ya, I'm all for longevity. '97 ford explorer, 4L V6, 160k + miles still running well.
What should it be?
*official Car noob*
Thanks in advance!
EDIT: now w/ 100% more poll.
And please post your indept reasons if possible. Thanks.
Oh and any brand recommendations? hehe
Aug 27, 2002
10,043
use the same oil, brand and weight that you have been using in it.
never never never never never change the brand/weight of oil you use in an engine once you make you're first oil change after the break in oil.
bret
2,099
mineral oil is good for breaking in an engine, then change to synthetic... i use mobil 1 5w 30.
chrisms
6,615
What the hell are you talking about.. who told you this?
jagec
24,442
Originally posted by: DanTMWTMP
'97 ford explorer, 4L V6, still running well.
nonsynthetic.
Synthetic is a waste of money in most cars. Unless you drive a high-performance car or a very new car, just stick to dino grease and save yourself some money.
dug777
24,778
4
i use a heavier grade when i'm driving hard for at least a few days (like across Oz ;) ), and a lighter grade in town for the rest of the time...
Eli
Super Moderator | Elite Member
8
Here, let me summarize how this thread will go:
alkhdnaoiusdhnaifkpodfmepfoidamsdoiahnfiuwoj change paisdjaoiuhdnsidoprmqwjeodjad oaifdjuaojfaikjweprjwqeohduw oil kjahdsauishdaoiujweoirhiudgh every sournewtpwontoirhoijwpijdferwpoierjwoiejrweoi 3,000 miles ahdaiusdhaiwodjqorbiugbuh liahduhdauwodjaioejwiejqei don't sdajfaohipesmjrtwptimwnqef switch apsmdaflknseiufwnefoie to aslidjaiusdhaiudojewdileniwe synthetic ajdoiuhdeiafheru before goihiurehjdoiajdqwrepoqjr breakin poaidhfeiuhfaiofjritohewyuij oil laisjndiahnds is oil laihoiuajdpoais is oil ahdsaiushdsdkas synthetic aoishdaudoaid oil piahsdiuhtodritj is aojiufeshfst a edjfoihjoer waste paojsfoishjst of paisdjuid money ohdfiuyadhgbuahureh your car oisadfhiufhjewrjtertijwmeik will leak khnfiejrhw more urehnweuybweufyhbe
dug777
24,778
4
alkhdnaoiusdhnaifkpodfmepfoidamsdoiahnfiuwoj change paisdjaoiuhdnsidoprmqwjeodjad oaifdjuaojfaikjweprjwqeohduw oil kjahdsauishdaoiujweoirhiudgh every sournewtpwontoirhoijwpijdferwpoierjwoiejrweoi 3,000 miles ahdaiusdhaiwodjqorbiugbuh liahduhdauwodjaioejwiejqei don't sdajfaohipesmjrtwptimwnqef switch apsmdaflknseiufwnefoie to aslidjaiusdhaiudojewdileniwe synthetic ajdoiuhdeiafheru before goihiurehjdoiajdqwrepoq2jr3 breakin poaidhfeiuhfaiofjritohewyuij oil laisjndiahnds is oil laihoiuajdpoais is oil ahdsaiushdsdkas synthetic aoishdaudoaid oil piahsdiuhtodritj is aojiufeshf9st a [edjfoihjoer waste paojsfoish8jst of paisdjuid money ohdfiuyadhgbuahureh your car oisadfhiufhjewr0jte0rtijwmeik will leak khnfiejrhw more urehnweuybweufyhbe
cliffs notes?
bret
2,099
that took me a min but i got it...
DanTMWTMP
15,908
19
cliffs notes?
change oil every 3,000 miles don't switch to synthetic before breakin oil is oil is oil synthetic oil is a waste of money your car wil leak more
TheChort
4,203
synthetic oil is thinner than regular oil, which explains the leaks
In older cars where tubes are more worn out, you run the risk of leaks in switching to synthetic.
d3n
1,597
I'll tend to agree with this. However I think this goes for more of a high mileage vehicle that was previously dino juice. Going Synthetic can really knock allot of the build up loose and clog everything up after a couple years have gone by. I know that it has 'killed off' some cars. I figure you would be ok on the first year or two if you switch from regular to synthetic.
Since you have a 97 I would go for Castrol High Mileage Dino.
Mobil One rocks. It lets me stretch oil changes to every 7500-10000 miles.
Dino I would go with a strait 3-5000 mile change interval.
The new Toyota I have Mobile One in since the wife often has the van tied up from getting oil changes. The Volvo 850 Brick I drive uses Castrol High Milage at 140,000. Still runs like new.
dug777
24,778
4
cliffs notes?
:beer: cheers :)
Aug 27, 2002
10,043
if you lose an engine, (I've lost 2) and the fault is with the oil, the oil company pays for your replacement engine. if you can't prove that you've had the same oil brand/weight in the engine from the get go, you pay for your replacement engine. go ask any certified mechanic.
of course if you don't know what was used all along, or have already switched oils in the past, it really doesn't matter that much, as long as it's quaility oil, if you have build up problems, I'd use an additive like Restore for one oil change and continue using what you're using now. aluminum block engines don't have near the same issues as steel blocks, and longivity is more of an issue of wear, and worn out gaskets. (my 99 ranger had 287k miles on it with out anything done to it aside from normal maintance....brakes/shocks/tranny service/etc.) when I traded it in.
Penzoil paid for my 2nd engine that blew btw.
DanTMWTMP
15,908
19
hmm. interesting.
chrisms
6,615
That has nothing to do with what you said. The oil company, let's say Mobile isn't going to pay for your engine if you've been using both their product and Chevron oil on and off for the past few years when your car breaks down. They'll tell you to go talk to Chevron. This is simple business, nothing to do with auto mechanics.
KarenMarie
14,372
That is EXACTLY what my b/f said... he is an expert....
he said that if you were gonna change, you should have done it after break in. Now you need to stick with what you already have.
dug777
24,778
4
especially if you live in a place with extremes of winters/summers temps, you'd be fvcking mad not to change your oil types :p
Eli
8
lol, ok.. i'll read the thread.
First and foremost, synthetic oil absolutely does not cause leaks. IF your car is already leaking oil externally, the leak MAY get worse if you switch to synthetic, the reason being that it's molecules are much more uniform. That's what gives synthetic oil it's low temperature performance.
What exactly do you mean by offers "better performance"? There are many facets to "performance". If you mean fuel economy, forget about it. If you mean oil longevity, you may be onto something. If you mean engine longevity, there are more important things than the specific oil you use.
It looks like your engine has pretty high milage already, at 160k. What has your oil change schedule been like?
What weight oil do you use?
Does your engine use any oil? Does it leak?
It's way too easy to get hung up on the oil, when thare are half a dozen things that are more important to the longevity of your engine.
Edit: Oh dear lord, the thread has already gone to hell in a handbasket.
Howard
47,982
11
Wouldn't it be retarded if synthetic didn't come in the same viscosity grades?
Eli
8
Umm, incase any of you didn't get it, that was a joke... lol
Please. Complete horsesh!t.
Bleh, you can use whatever oil you want for breakin. There is not an oil on the planet that will "prevent" an engine from breaking in. Should anybody invent such a thing, well.. we'll all know about it.
Synthetic oil manufacturers don't recommend using their oils for breakin because it is pointless. Why bother using expensive synthetic oil when it is going to be fouled because of solid particles in ~1,000 miles? Use the cheapest oil you can find. There's no need to go non-detergent or anything "fancy", unless you know what you're doing and are going to break it in, in your garage and around the block. Most people just drive normally during break-in, and in that case the additives in regular engine oil are going to help, especially if they go beyond the specified break-in period.
Careful there. City driving is actually severe service compared to highway travel.
Synthetic oil is NOT "thinner" than regular oil.
Worn out tubes huh? What tubes are you speaking of? :p
If the engine does not leak before synthetic, it is unlikely that it will leak aftwerwards.
There is nothing special about Castrol or the "High Milage" oils. They may have a bit more aggressive additive package, but.. you should have that anyway.
There is no evidence that synthetic oil will "knock" anything loose. While quality synthetic oils do contain a more robust additive package, the detergency difference isn't that profound.
Ok, I was with you for the first paragraph, and then you recommended using an oil additive. Folks, DO NOT under any circumstances put ANYTHING into your crankcase but pure, virgin, unadulterated engine oil.
Let's hear more about these replaced engines. First, how on Earth did you go about proving beyond a reasonable doubt that it was the oil's fault that your engine failed? It's virtually impossible, although they would probably oblige you IF you prooved that you had been using nothing but Pennzoil for the entire life of the engine. Was this indeed the case?
If your boyfriend said that, he may be an expert - but it's not at engine oil. :) There is no logical reasoning for that stance. It doesen't make any sense.
*pant*
Eli
8
Dan needs to answer the questions I asked in my first post before I can seriously recommend something for him.
In addition, where do you live? What's the terrain like?
