Originally posted by: brikis98
Originally posted by: njdevilsfan87
To gain body mass. I'm 187-188lbs at 6'2'', and at about 12-13% body fat as by calipers. I'm going to attempt to gain a few more lbs, and start cutting it all off (as in stop lifting the weights entirely and drop to 10% body fat doing mostly cardio, and some resistance training, while in calorie deficit). My original post doesn't really relate to this. I'd be better off probably just sticking to weights entirely... but that just doesn't feel right to me.
* If you're trying to
gain body mass, cardio of any kind (including swimming) will be somewhat counterproductive.
* On the other hand, if the goal of your cardio is actually to eventually help you cut weight, then it doesn't matter too much which type you do - the only real effect of cardio on weight loss is as an efficient means of increasing how many calories you burn. Cardio certainly has other benefits (e.g. increased stamina & endurance), but none of them matter much for weight loss. Therefore, just do whatever kind of cardio you enjoy and can do consistently.
* Incidentally, while swimming certainly burns a ton of calories, swimmers do seem to retain some extra fat over other endurance athletes. Not sure if this is because the water is cold or fat helps buoyancy, and I don't know if it would have any effect on a recreational (as opposed to competitive) swimmer, but it's worth considering that from a pure fat loss perspective, swimming might not be the ideal choice.
* It is a bad idea to
reduce your resistance training and do "high reps" while in a caloric deficit. You need to give your body as much incentive as possible to maintain your metabolically expensive muscle mass. This is best accomplished by (1) keeping protein intake very high, (2) doing plenty of resistance training and (3) ensuring that the resistance training you do is
heavy, which by definition means low rep. Reducing the intensity/volume of your current weight training (ie, 3 days per week to 2), will just signal to your body that your muscles aren't that important and it'll be happy to digest them to make up the calorie deficit. And I don't know who spread the "high rep for weight loss" myth, but it does NOT help you burn any more fat and it will NOT be as efficient at maintaining muscle.
