Originally posted by: Apex
Originally posted by: Pacfanweb
Apex, so you have a shop with a dyno?
Yeah, used to have a DynoJet (inertial type), but upgraded to a DynoDynamics (eddy current). The DynoDynamics is about 2x the cost at ~$60,000, but worthwhile, IMHO. The very very small diameter, light rollers give you an extra measure of safety (tap the brakes and they stop instantly unlike the gigantic, heavy rollers on most dynos) when tuning, and they're extremely sensitive.
IMHO, the real dyno error issue (if you have a well maintained eddy current dyno) is the operator. Use one experienced operator for everything, use the intake probes and correct every time for ambient conditions, always place the fan in the same location, plus run HUNDREDS of passes, and you can get a good picture of what the modifications you're doing to the car is doing to the powerband.
In terms of the intake (in this case, we used the
BMC drop in filters), if you can get a consistant gain over a wide portion of the RPM band (not just a few points at peak or at the initial throttle application) over many MANY runs, over many many cars, in many different states (heat soaking the car, and doing cool runs), back and forth (stock to aftermarket, then back to stock for multiple dynos each time), you can be reasonably confident in the power difference if any. In this case, there definitely was.
Again, I don't dispute that fact that most cars will show no gains with just a drop in filter. However, I believe there are definitely exceptions, as we have seen. :thumbsup:
