- Jun 25, 2004
- 241
- 0
- 0
folks,
Second Survey is ready!
ok...let's try this again.
NOTE: this survey will require a QUICK (First, Last, Email Address) in order to work correctly.
NOTE 2: This information is confidential and will not be parsed into mailing lists or ANY other form of data processing field (except for my graduate project).
Ok, to start:
1.) go here: http://www.flickerdown.com/phpsurveyor/index.php?sid=2 and do the registration.
2.) submit your results and you're done.
NOTE: there's a ton of PHP debug crap going on...just ignore it.
Thanks for your help! there'll be 1 more survey appearing in the not-so-distant future.
dave
NOTE: under absolutely NO CIRCUMSTANCE will your email, name, etc. even be recorded in my data tables. i've double checked against the tables i've set up and the only information present is your IP address. all other information is scrubbed IN PROCESS. I do not want your email address, name or otherwise.
Ok, to start:
dave
