The pro vs against debate is irrelevant here. I was given a budget of 200 and for that I had to either buy a used computer or assemble a new one. Usage is e-mail, skype and web browsing. Movie playback / youtube distant 17th.
Since I already had lots of parts for a new one, I took that route and still kept the actual expenditure low enough.
I have seriously considered i3 and llano, but both of them required 200 or more just for MB and CPU. The top-of-the-line MB for this zacate was 150 and this tipped the scale in its favor.
Update:
The whole setup takes <20W at idle
33W at full load running Prime95
It also plays my BD-rip of Gladiator with no frame dropping at 50% CPU usage (ffdshow DXVA).
The codecs installed are SAF 6.00 (not unlocked)
You can get an A4 Llano for much cheaper than that. Still not as cheap as Zacate though.
I do think that we're within a generation of having something in a similar power profile that doesn't suck though. I think something in the range of the stock Athlon II 250 performance levels would be a great deal at 10 watts or less, and I'm sure it's close.
300 euro is $400. For $400 I'd get a llano A4 notebook instead.
It does not work that way.
You may not be able to go to best buy but I'm sure there are sales and deals jsut like here.
The E-350 is 18W, not 10W. And yes, we're there with mobile CPUs. The E-350 is AFAIK the same CPU whether in an ITX motherboard or a notebook. You can get similar wattage Sandy Bridge mobile chips, but they mostly find their way into notebooks.
Then again, even the desktop Sandy Bridge chips get within spitting distance of power usage.
Side by side comparison using a fresh windows 7 install on both Zacate (not sure of which one) and my old...archaic 2.8 P4 using an AGP 7600gt (agp version of that card doesn't do decode like the pcie version)
1080p video - Zacate
EVERYTHING else (general usage, responsiveness) - My old P4
Not by a huge margin or anything, but the P4 still hung in there. Its rather quick actually loading up Office 2010, web pages, flash videos. The only issue is that its an inefficient pig of a processor that sucks up juice.
Zacate is still good for what it is.
All the 939 systems I know are dead. How can you act like this? How can you be so cold?
It's what keeps me alive.
No, it's what keeps you alone.
It's too bad Asus or whomever doesn't make a mobo with the mobile SB socket and notebook ddr3 slots, it would make for an awesome itx platform. It would blow the doors off of Zacate and Atom, and be worth spending a few extra bucks on for sure.
+1 for bond quote, -1 because I can't get rid of my 939 systems, they keep working well despite being inefficient. Okay, I'll give you +2 for the bond quote 🙂
Naturally, buying zacate for price/performance doesn't make much sense. It's actually ridiculously expensive.
Been there, done that. If you put some electrical tape or similar around the screw inside the cage, the drive will be very secure, even with just one screw (or, you could get a 2,5->3.5 adapter).Had som problems mounting the disk: The monting holes are for 3,5" drives only, so the Scorpio is hanging off a single screw 🙁
Flash acceleration is screwy even with fast setups. Just one of those things. The bad bit is that there isn't the CPU power to use, instead.Youtube videos play without problems. 320p == 30% (@800MHz), 720p == 70% @ 1600MHz and 1080p is 80% with frame droping. Trying to figure out the problems.
While that's a fairly long wait time, I've found this to be common with Windows 7 when (a) running <4GB, and (b) having indexing and superfetch on. I can't say what exactly prevents it, except that I always disable indexing everywhere possible, have >= 4GB available for Windows to use, and disable superfetch, and it doesn't happen on those PCs.The biggest gripe I have with it is that sometimes it scribbles around on the disk and trying to run an app results in waiting. Usually the waits are around 10 seconds and are common enough for me to notice and get pissed over it. I would most definitely not ever run this setup without a SSD.
Somewhat agreed. I'm just waiting to get a call that just such a machine (4400+, 2GB RAM, now Win7 pro) needs to play videos, recommend a cheap video card, and then not hear anything more about it until at least 2015 🙂. If you weren't gaming, the A64 X2s have managed some serious longevity. Even the later P4s, with more modern software, feel far more poky and bloated, IMO. In general, though, Zacate fills a niche: cheap and low power. For performance, you have to go elsewhere, and generally spend more money up front, or in electricity (most of the US need not worry about that, but other parts of the world do).I just found it to be way to anemic. it is silly in 2011 to have a cpu struggle at all with some flash and 1080p videos. just a regular Athlon X2 provides a WAY better daily user experience.
heh I have three X2 4400's and no boards. Don't want any either.
LIFO:
@hoorah: I can't really complain over system responsiveness. Pretty much every time I have to wait, I wait for the disk. I suppose some windows readyboost flash would help a lot here, not to mention a proper SSD. However, after toying around with this baby I can't really say I can recommend it for HTPC use. It will skip frames while processing any interlaced material or any full HD material that can't be played through DXVA. It can however decode 720p in CPU with ~70% CPU usage. Internet surfing is responsive and quick, no complaints there, but flash video is again limited to 720p. All being said and done, I'm much happier with my choice of i3 2105 for my own HTPC.
