VirtualLarry
- Aug 25, 2001
- 56,587
- 10,225
- 126
You really and truly are an idiot. What IS "obviously irrelevant" is posts about Saddam and WMD.He is playing number games with what was obviously irrelevant. Since a 600 watt system would toast bread. VA is a function of the load - not a UPS. He should have known that. A second reason to ignore his posts. Does not matter if a battery backup is 600 VA or 600 watts. It still provides sufficient power to his computer. As did a 500 watt or VA battery backup. Just a third reason why his posts about a 600+ watts were obviously bogus. And best ignored.
I posted a very relevant SOLUTION to the problem.
The OP has what I believe to be a 600VA UPS. NOT a 600W UPS? Why? Because of the way that UPSes are marketed. You see "650VA" on the box, and then if you're really lucky, you find the wattage rating of 350W hidden in small print.
*To size a UPS, for a PC, you need to look at the wattage rating, and then look at the wattage drawn by the PC at the wall (with a Kill-A-Watt), and leave perhaps a 10% margin. *
Clearly, the OPs system with a high-end gaming card is drawing at the limit of the UPS's wattage, which I estimate at 350W or so.
As for "Does not matter if the battery backup is 600VA or 600W" - that only proves your ignorance about real-world UPS sizing and marketing. It absolutely DOES matter if the UPS is rated 600VA, or it is rated 600W. Because if it's rated 600VA, that means that it is really only rated for 300-350W. Which is what the actual important rating is. (And most likely why it is beeping.)
"A 600 battery backup". Now you're not even addressing whether the battery backup is 600VA, or 600W. There is a very real and appreciable difference between the two, and that is the entire nexus of this discussion.Why post the same irrelevant arguments rather than address the OP's problem? But then that requires information he has not provided. As you admit, those recommendations exist without relevant facts. We know a 600 battery backup should be sufficient - for three reasons. In every post, I keep returning to another relevant fact. We need more information from the OP - and quiet from the naysayers who only create fears and confusion.
