Monel Funkawitz
- Oct 12, 1999
- 5,105
- 0
- 0
I would disagree that a magnet is a potential storing device. In order to obtain energy from a magnet you must move a conductor through the magnet's magnetic field. This movement induces an electromotive force in the conductor (voltage). You are transforming the energy of moving the condutor to producting a voltage in the conductor. The magnet itself can be considered as a catalyst in this transformation.
In short, permenant magnets can exert forces on things, but they won't increase the total energy of a system. Also, even though it seems like your getting 'free' work, you have to put the same work back into the system to seperate the magnets after they collide.
Originally posted by: DML1001
painkiller:
They both have potential energy. If you drop a stone, the stone moves toward the earth, and the earth moves toward the stone (by an infintesmal amount).
The force on both objects (the stone and the earth) is the same, but the distance they travel is not since F = ma, and the mass of the earth is so large the corresponding acceleration is very small.
As for a system of magnets, its basically the same idea. Typically, if you take two magnets and let them go, they both move toward eachother and meet in the middle. So, both really have potential energy.
Anyway, where are you going with this?
sao123:
Also, one quick note. When you pass a magnet through a coil and generate electricity, the current generated in the coil will create a magnetic field that will work to OPPOSE the motion of the magnet. What this means is that when you use a moving magnet to induce a current in a coil, the magnet will ALWAYS be slowed down. Expirements have shown that the amount of kinetic energy lost by the moving magnet is equal to the energy generated (in an ideal situation with no resistance, etc...)
The energy stored in a magnetic field is essentially the total amount of work required to assemble a system of moving charges.
The concept of perpetual motion itself is not illogical. Indeed, all objects in the universe are in motion on one level or another, thus the natural world disagress with the common assertion that perpetual motion could not be achieved through mechanical means. The problem with the ideas are that the term 'perpetual motion' is often seen to imply 'getting something from nothing' or having more output than input, which is fundamentally incorrect. Perpetual motion is literally that which is without motionlessness.Originally posted by: Fencer128
Why are we inundadted with "perpetual motion" threads of late?
We need a sticky that says "please read up on the illogical aspects of perpetual motion, as mentioned in every other perpetual motion thread, before posting"
But isn't it all relative? Ok, so if the universe is collapsing, you'ld have to find something at a higher rate of motion than you in the same (or similar) space. Isn't that impossible?No, I'm not trying to argue semantics, just pointing out that obviously perpetual motion can (and has) been achieved in the natural world, and to date we have been able to build things that have emulated the natural world relatively well -- even if science and our understanding of the natural world is on the whole in its infancy. Magically creating energy from nothing is another matter entirely.
The concept of perpetual motion itself is not illogical. Indeed, all objects in the universe are in motion on one level or another, thus the natural world disagress with the common assertion that perpetual motion could not be achieved through mechanical means. The problem with the ideas are that the term 'perpetual motion' is often seen to imply 'getting something from nothing' or having more output than input, which is fundamentally incorrect. Perpetual motion is literally that which is without motionlessness.![]()
DML1001:
I've been doing some reading and have found no indication of this theory anywhere...can you provide references & equations to back up this claim?
Originally posted by: sao123
DML1001:
I must disagree with this assertion.
Place any conducting particle or group of particles within the radius of the magnetic field and its associated magnet. An actractive force is present between the conductor and the magnet. If the radius is small enough, the magnet is strong enough, and the conducting particle in not fixed to a point, the actractive force can be great enough to move the two objects closer together.
This shows proof of potential energy stored in a magnet and its associated magnetic field. It may be noteworthy that this potential energy probably will only manifest itself in kinetic energy and not electromagnetic. The magnet is more than a catalyst in this way.
Fortunately using electronic magnets allows them to shut off the magnets just as two of them come together at their closest point (they never really touch)...then using momentum to continue the journey away form the magnet to a point at least 51% to the next magnet, at which they then turn back on and do more work. Momentum must be some form of energy (kinetic) because it still has the ability to do work...moving the copper wire through a second all encompassing magnetic field, creating electricity. It takes some energy to power the magnets to turn the rotary, but i think its just over 50% of the power created because the magnets are on for only 50% of the cycle, but electricity is created for 100% of the cycle. All figures are +- a few percent to allow for friction.
This clearly dictates that a magnet is be a source of potential energy, by storing the work that was done during the process which (permanently) stores the magnetic field onto the magnet.
The work that is done is accomplished by... Aligning the angular momentum (a vector quantity describing the orbital & spin of an electron) of the electrons of the atoms for a given region of material, (which creates by definition "the magnet".)
Based on this, there is no perpetual motion machine, nor does it defy the conservation of energy. The magnet will eventually run out of magnetism (energy drain and entropy laws) and energy is conserved.
We need a sticky that says "please read up on the illogical aspects of perpetual motion, as mentioned in every other perpetual motion thread, before posting"![]()
