Aharami
An M400 I think
woah really? need pics asap!
An M400 I think
an M5 is not just a luxury sedan
Not too sure, will have to dyno when it gets back.
After all said and done, it should be over 700 at the crank. It's a pretty conservative kit at just 6 psi. It's designed for reliability and usability, with a torque curve that mirrors the stock one. OE compression ratio is 12.0:1, so going much over 6psi this isn't all that worthwhile on 91 octane.
Did you remember to strengthen all of the other parts of the car? There are lots of videos on the net of cars with enormous turbochargers and it blows the car apart. Transmission all over the road :biggrin:After all said and done, it should be over 700 at the crank.
I've lost side-view mirrors before.Did you remember to strengthen all of the other parts of the car? There are lots of videos on the net of cars with enormous turbochargers and it blows the car apart. Transmission all over the road :biggrin:
Did you remember to strengthen all of the other parts of the car? There are lots of videos on the net of Civics with enormous turbochargers and it blows the car apart. Transmission all over the road :biggrin:
Wow, 130 mph at streets. That thing would be downright scary on the big track... 700 hp and 2 tons of German auto screaming down that 1/2 mile straight.
Yeah, I was surprised at the speeds it could get to. The M5 is a monster above 120mph or so. It accelerates really hard at high speeds. At just 560-570hp, above 140mph, it's accelerating harder than a 600hp 996 TT. Pretty crazy considering how much smaller the 996TT's frontal area is (and of course, the power to weight ratio difference).
The M5 is probably not geared for high speeds; consider its 155mph limit.Yeah, I was surprised at the speeds it could get to. The M5 is a monster above 120mph or so. It accelerates really hard at high speeds. At just 560-570hp, above 140mph, it's accelerating harder than a 600hp 996 TT. Pretty crazy considering how much smaller the 996TT's frontal area is (and of course, the power to weight ratio difference).
:/ Are you sure.... oh wait are you talking about feeling like it accelerating faster or it actually is?
Because heavier car, less HP, and less aerodynamics, is somehow faster, I just have a hard time wrapping my head around that.
Tallerize the final gear ratio ftwMy 6-speed 996TT with Ultimate Motorwerks K16/K26 Stage II turbos, custom airbox w/BMC filter, EVOMS tubular manifold, 3" RPi exhaust, RPi high performance bar & plate intercoolers, Sachs uprated clutch, lightweight aluminum flywheel, ESS software tune, C's shifter, H&R coilover suspension, HRE forged wheels, carbon hood, 10-lb battery, CF GT3 seats, Techart wing:
Actually is.
If the M5 were geared for top speed of 160mph (redline-limited vs power-limited), I would certainly expect that it slaughter the 996 Turbo which is geared for a top speed of ~198 mph.
3.99:1, 2.65:1, 1.81:1, 1.39:1, 1.16:1, 1.00:1, 0.83:1 with a 3.62:1 final.Well it certainly isn't magic. Maybe the M5 is in 5th or 6th at ~140mph, and who knows what the ratios are?
