geno
- Dec 26, 1999
- 25,074
- 4
- 0
Originally posted by: Howard
Of course, it all depends on how well you insulate the turbine housing (and exhaust manifold(s)/header(s) if you want better emission control/power).Originally posted by: Evadman
If you are looking for an off the shelf forced induction system, in general terms a supercharger will be less expensive. Turbos can require some custom metal work and fabrication since both the exaust and intake are messes with. Superchargers are only intake and a belt.
Turbos will also raise underhood temps quite a bit comparied to a supercharger.
Are you talking about heat-wrap? I've heard bad news about using that stuff anywhere near a manifold/header on a turbo setup...
