SUPER HOT !!!! "xp 2100+" xp1600+ for $51 from newegg. It's crazy !!!!!!!
SlinkyDink
99
I have that cheap 80mm thing from SVC. I dont think it cools that well frankly, but its only $5. Be very careful with the clip. I'm using it on my GF's duron 1ghz, and it crushed off the corner of the chip the first time I used it, and I've never damaged a cpu ever before. The second time I put it on, the corner of the sink was stuck up on the highier area of the ZIF socket, so only a third of the chip was actually touching the cpu. The temp reached 60C under idle when like that.
The chip is still working ,although with a corner chipped off.
Make sure you take the fan off the heatsink before putting it on, or put a flathead screwdriver down between the fan blades to press the clip on downward. Also make sure the heatsink is lined up over the chip and not on top of the high area of the zif socket. Overall its an ok heatsink, not great, but still good I guess. Although I wouldnt put much confidence in it overclocking an XP1600.
cdc2000
19
I bought this chip (1600+) and the Gigabyte GA-7VRXP motherboard.
What are the settings that I need to change out of the box to try to run this at 166FSB. I noticed there was an FSB setting under "hardware monitor and other" or something like that. Also, I have PC2100 memory, but I believe it will run at PC2700 from what I understand. Do I need to change that sometwhere as well? Also, do I need to change any dividers? Jumpers? Basically, what do I need to do to get this overclocked from scratch?
kimj9
13
good processor.
good price.
good vendor.
good deal.
just one thing though, since people are mainly buying this to overclock at a cheap price.
i wonder how of you can tell the difference between 1.4Ghz - 1.8Ghz?
i guess free performance doesnt hurt though. ;)
my opinion is this deal is great for people who got durons under 1Ghz. :D
ww4397
1,178
On the topic of the GC68 HSF, I have one cooling my 1800+ (@1900) on a MSI K7T266 Pro mother board. (I won this cpu/mobo during the AMD Extreme Performance Tour last fall. Thanks to AT for bringing that program to my attention.) The K7T266 reports two temperatures: 1) CPU temp and 2) System temp. The GC68 keeps my cpu to within 1-2 degrees C above the System temp.
RSG2
166
I can't say that I have anything to comment on technically here. However...
How many times have you guys pointed out examples both personal and posted elsewhere to have them shot down as untruthful? Thre really needs to be a sign on threads like this that says "Don't feed the troll"...;)
stevejst
Banned
May 12, 2002
1,018
ww4397:
ww, you are either dreaming or getting defective reading. No cooler can do something like that, not even "the miraculous GC68."
How far will these fish tales go? Anybody more?
drewdogg808
1,513
i guess i'm just really unlucky...neither my xp1900 nor my agoia xp1600 can hit 1.8 ghz...in fact, i can't even get them stable above 1.75ghz...
BigJ
21,330
What motherboard are you using? Try flashing the BIOS to the newest version, or reseating the heatsink on the processor, etc. Also, make sure you're memory speed is not set to HCLCK + 33 effectively giving you memory at 199mhz (definitely above PC2700). I found when I set my fsb to anything above 165mhz it wont boot up because it automatically switches to hclk + 33 and no other options are selectable (ie. spd, etc) on my MSI board. But the board runs fine at 165mhz x 10.5, I think I might need to flash to a newer BIOS revision, see if it allows me to set them synchronously.
drewdogg808
1,513
msi kt3 ultra aru...i'm sure the heatsink is seated properly..but i haven't noticed the HCLCK + 33 setting...i've been able to get above 166 fsb though...only when i drop the multiplier to 10 (can go to about 10x174), but i have to relax the timings on my memory significantly.
BigJ
21,330
I have the same motherboard, and it always sets the memory to HCLCK + 33 on my, and its damn pissing me off. Then again, mine also isnt unlocked like yours, so I'm doing purely FSB oc'ing. Set the FSB to above 166, and then check ur memory and see what its at, cause it switches automatically for me. I have the exact same mobo.
ww4397
1,178
Originally posted by: stevejst
ww4397:
I just "call 'em as I see 'em" and Mother Board Monitor ver5 is reporting the temps as I said in the post above. Maybe its a defective reading as you suggest. But the "proof is in the pudding" and this machine runs flawlessly and is rock solid. So, defective reading, fish tale, wives tale or tall tale or whatever, the GC68 is not causing me any problems whatsoever.
RobsTV
2,520
That must suck to be so unlucky as to not be able to get "more than" XP2100+ speeds ;) ;) ;)
1.73GHz is what XP2100+ runs at.
If you need to reduce memory settings to achieve higher FSB speeds, then you probably have outdated memory.
At least that tells you that it's memory and not the CPU holding you back.
While most brands of PC2100 can hit PC2700 speeds, (166MHz), not all will.
The best memory today seems to be the Samsung PC2700 DDR ram sold at Newegg.
Many are hitting FSB speeds of 200MHz (400DDR) and higher with that memory. It was around $75 for 256meg a couple weeks ago.
Lot's of cheap motherboards out there.
I would hold out for next boards like KT400 if possible, but a good old cheap board, that hits 166MHz,
is Abit KG7 priced at $39.
Jedibus
584
As an add-on to RobsTVs' suggestion about the Abit KG7, here's a site dedicated to that line of Abit boards: SITE
Between that site for info and the price of this board, I'm having some problems not pulling out my credit card :confused:
drewdogg808
1,513
thanks for the advice RobsTV....i did order the kg7 a few days back, should be here any day now...i also just picked up the kr7 raid too. :D
but i'm starting to think my memory is holding me back. i guess some people have had better luck with crucial 2100 than i have. i can't quite hit 10.5x166 for some reason, but i can hit 10x173 (although memory timings relaxed, i need to do more stability testing). but could it be my current kt3 ultra holding me back? or just unlucky cpus? sometimes i wish i didn't know about overclocking...i spend waayy too much time tweaking with settings and running tests. talk about addictive. ;)
loup garou
35,132
Grr...I have the same problem with my kt3!!
stevejst
Banned
May 12, 2002
1,018
ww4397:
Since you are obviously getting defective reading ... do I have to explain that? ... you really don't know what is going on.
For all you know your CPU could be running 70 or 80 C and you wouldn't know, would you? It won't burn at that temperature but it will die much faster than if it is running 40-50C.
Go to BIOS check the temperature there and if it is the same nonsense then you either have sensors wrong or a defective motherboard. That is not that unusual with "refurbished" motherboards in particular with Epox.
Pilsnerpete
2,060
mwave is a great company too. nice RR average. I had a super heavy order from them little while back and it was less than it woulda been @ newegg.
Is that poop I smell?! good God!
sleefer
912
First of all, I think some of you guys owe DaHan an apology for trashing what was a decent post. I came to this post late in hopes of finding information on results of people that took advantage of it. Instead I find tons of opinion postings that have nothing to do with the original posted deal. I would suggest to some of you that if you want to continue to discuss off-topic items or take shots at each other that you take them to the proper forum. Some of us here would like to know if you got one of these cpu's and whether or not you can o/c it, not what your opinion about it if you don't or a h/s fan that you don't own.
RobsTV
2,520
Thanks sleefer for putting this back on topic.
Sorry I contributed the off topic.
Let's try doing just what you asked, which I believe was, does the Newegg Xp1600+ you get overclock?
Got two XP1600+ form Newegg, and both had no problem overclocking to XP2100+ speeds.
drewdogg808
1,513
i got one xp1600+ from newegg...received an agoia. overclocks to xp2000+ very stable, can get up to xp2100+ speeds but not as stable. still, an excellent bargain at $66. i wouldn't hesitate to order one.
007
39
Just got mine, an agoia. Overclocked straight to 9.8 gigahertz! Only mod necessary was adding a 3.8 gigawatt flux capacitor and a small dilithium crystal. Didn't even require a heatsink! Newegg rulez! ;)
PHiuR
9,539
mine should be here tomm :)
you guys who are overclocking it to 2000++ speed what hs/f are u guys useing?
Sahakiel
1,746
Originally posted by: davidos
Yeah, I'll probably get the Epox KT333 board or the MSI basic KT333.
I keep getting IRQ_NOT_LESS_THAN_EQUAL errors with my Shuttle AK31 v3.1. Is that a motherboard thing or a Windows XP issue? and are there any solutions?
Highly off-topic, but after reading the rest of this thread, well... Anyway, someone else might have this problem.
I had that issue on my 8K3A+. Took me half an hour of rebooting, playing MOH (Games are great stress testers. :p), and changing settings to figure it out. At first, I thought it was the CPU, since I'd underclocked and undervolted it due to bad A/C in the room. Then, I changed memory settings. The one thing I changed that seems to have cured the probelm was the queue depth. 8k3a+ has a setting for 8, which seemed high at the time, but I had borrowed some good RAM (Corsair PC3000 C2) and thought it would work. Dropping that to 4 solved the problem.
Steve: You're a stupid fool.
Gary: You're an arrogant ass.
and me: I'm a natural-born tightrope walker. (see my signature)
Price has a factor in quality. Higher-quality = higher price. However, this only applies to the same process. Different processes have different price/quality trade-offs. You would think the Intel vs AMD wars would've taught us something.
I am inclined to believe the wives tales and surrealist legends about 1600+ AGOIA. My 1700+ AGOIA will post at 162 default voltage and a HSF that barely kept my previous chip (AXIA 1.2) barely below 60C under load. It won't post a second time, though. Gee, wonder why.
I could always use a new HSF, but since this room doesn't have good A/C (barely keeps one guy comfy during a heat wave) I see no point. Besides, it's now underclocked to 1100MHz 1.4V (Thank you, Epox) and does about 39C full load with the same heat sink with 28-30C ambient. MBM picks it up as 92C; guessing it's the VCore.
Overclocking is an exercise in patience and statistics. The majority of each stepping will reach the same ceiling. i.e. 1700+ MHz for AGOIA, something like 1450+MHz for the first steppings, maybe 1200+MHz for the engineering samples. Depending on your multiplier, your FSB will be different. The really lucky chips of each stepping will, of course, hit higher speeds. Due to their lower probability, supply is low, thus the higher prices for the upper end. And then, there's the really unlucky chips that fail and the not-so-unlucky ones that can barely run at the cutoff. You do hear of the latter ones occasionaly when you see a post by some poor guy who's CPU crashes after bumping up the FSB 2MHz.
It's no secret that AMD and Intel survive by selling cheap CPUS since the high revenue chips that cost an arm and a leg don't sell as well. That's why occasionally, chips that can run faster get binned lower. Much better to sell a processor for 15% profit in two weeks than to have it take up storage space for two months to get the same profit margin due to falling prices.
So, in conclusion, my undervalued opinion is that this WAS a good deal. Up until the thread crapping and Newegg to raising prices again. My supporting statements are above, and this circus act is over. *dismount and bow*
