Originally posted by: ElFenix
turtle wax!
Originally posted by: Marshallj
S100
If you need it tomorrow, buy Meguiars at your local auto parts store. Their 3-step -- cleaner, polish, carnuba -- waxes are actually very good, inexpensive and foolproof. If your car is newer, has clearcoat, and the finish is still very good, don't use your orbital -- there's no need. Instead, just apply and remove the wax by hand with soft terry cloths.Originally posted by: stev0
going to be waxing tomorrow, i have a orbital buffer that i use along with some mothers cleaner wax, but what is a good 'finishing wax' or a polish that i should use afterwards?
Originally posted by: Mutilator
Visit Autopia for all your car detailing info needs.
That being said I'd say Zaino is a great polymer... P21S (or S100) is one of the best carnauba waxes you can get. Zaino you buy from a local distributor or mail order. I buy most of my stuff from Properautocare.com. Might start using the Autopia-Carcare store to support David B.
