1. i've read a lot of reviews where it says the NorthBridge fan on the IC7 is extremely loud..........how loud is extrememely loud? 35 db? 40db? 50???
2. wut should i replace it with? a heatsink? or a heatsink and a fan?
3. i'm going to try and run a 2.4C OCed to 3 or near 3 on the IC7.......so will replacing the loud IC7 fan with the solution from question #2 keep it cool?
thanks a bunch
thanks a bunch
