Muse
I have a serious drainage issue on my property, right next to one side of the house. The driveway is there and I used to park cars in that spot and I think those 2 ton cars had something to do with the depression there. Also, the driveway isn't well engineered, it's just two strips of concrete with dirt between, the strips being about 18" wide.
When it rains a fair clip a puddle forms there because 1/2 my roof drains down to where the runoff accumulates at the depression. I was busy overhauling my garage last summer so couldn't get to the drainage problem. Some people suggested installing an exterior sump pump, but the likely spot was nixed by the gas company because there's gas lines where the pump would go. That is my deduction after they came out and looked where I marked where I wanted to dig. I never saw them, they just nixed the spot and left.
Well, to get to my current problem -- draining that puddle to the street. What I've done for about 2 years now is put a submersible 1/6 hp portable utility pump at the low spot in the puddle, attach a garden hose and spill the water to the sidewalk where it goes to the gutter.
I woke at 3AM today, hearing some rain, checked the puddle (been doing this since it started raining about 36 hours ago), and the puddle was huge. I started the pump (plug in the extension cord into my wall indoors and look out the window with flashlight), and it pumps and then turns off. Last night, I forgot to turn the pump off one time when the puddle went dry and it ran about 7 minutes and was off. I think this pump has an automatic shutoff when it runs dry, gets overheated. If it sits for 20 minutes it will work again. So, this morning at 3AM it was functional. But it would shut off after 1 1/2 to 2 minutes. I would let it sit ten or more minutes and it would again work for 90-100 seconds and turn off. The puddle was huge because the rain kept falling fairly hard and steady and I had to use a system I devised to transfer water to the street using 5 gallon buckets. Meantime, I would use the pump for 90-100 seconds every dozen minutes or so. A couple times it worked for almost 4 minutes but most every time it wasn't more than 100 seconds.
This particular pump is the Ace Hardware 40003 1/6HP Submersible Utility Pump. See the picture below.
I'm thinking one of two things:
1. There is something inside the pump that's screwing it up and taking it apart I might be able to restore it. I've taken it at least partly apart a couple of times already when it wasn't working properly. Right now, though, the flow looks typical, not restricted, so I don't know what taking it apart and inspecting/cleaning might accomplish.
2. The auto-shutoff mechanism of the pump was somehow altered so it shuts off too readily. I don't know what that mechanism would be or if I can do something about it.
I figure I'm going to buy a 2nd pump because I have found that I can't depend on one. However, I'd like to fix this one instead of having to buy 2 more.
1. Can I fix the one I have?
2. Buying a 2nd... get another Ace or some other brand/model?
What do you think?
Here's what I have:
What do you think?
Here's what I have:
