- Dec 13, 2022
- 7
- 4
- 36
Here's my configuration:
i5 6600K overclocked to 4,5 ghz with aftermarket heatsink
Newly bought RTX 2060 Super
16 GB of Ram
144hz Acer G-Sync monitor
I had just replaced my of 660 GT videocard, but I noticed some nasty low performance visual effects everytime the frame rate goes below 144 fps (my native refrsh rate).
Basically, even if I get a respectable 100 fps (or 110, or 80, generally everything slightly below 144 fps) the result looks like the game is running at sub 60 fps, with a really nasty effect.
I tried fiddling with G-sync, V-sync, anything, it just won't work. I am trying to play some old games like Starcraft 2 and Sudden Strike 4 and the scrolling lag is unbearable.
Same results on newer games like Chivalry 2.
Basically, unless the game I play runs at 144 fps or very slightly lower, I get horrible performance like the game is running at 30 fps, despite the fps counter reporting 80-100.
Video drivers are updated.
I tried removing the cpu overclock, zero results.
CPU temps are well below 60 celsius, even with overclock and cpu at 100% load.
Monitor is correctly set to 144 hz and Gsync is enabled in both fullscreen and windowed mode, according to nvidia panel.
What do you think is wrong?
16 GB of Ram
