stupid audio connection question
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
There should be a hole in the "screw" part of it, is that the hole you're using?
What gauge wire are you using?
HaxorNubcake
1,983
oh...i guess i'm probably putting them in the wrong way then.
On my receiver they go in from the side...what happens if i over tighten?
Howard
47,986
11
The top hole is generally for banana plugs. Try unscrewing the nut to reveal a hole that goes through the side of the post.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Yeah, that's not right.
I'll take a picture, hold on.
d33pt
5,654
first of all, that hole is for bananaplugs. secondly, your "tightening" is actually "loosening."
Howard
47,986
11
22222 posts!
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
22222 posts!
Not anymore :p I wasted it in another thread ;)
UncleWai
5,701
68
You just put the cables in the place where the jumpers are and twist them all together. I would just get four banana plugs so you have more mobility.
