stuck in safe mode
SOONER
323
My computer is stuck in safe mode. I am using Win 98. I have tried holding ctrl key and selectin normal but this hasnt helped. What else can I try? Thanks.
John
Moderator Emeritus<br>Elite Member
[*]look in the device manager under EACH category (except system) for ghosted (duplicate) devices, and remove the top one.
start/run/msconfig
[*]uncheck the startup group, autoexec.bat, config.sys and apply.
[*]reboot when prompted
SOONER
323
John,
Thanks for the help. Tried both suggestions. Still stuck.
Any more ideas?
Thanks.
John
Pull all expansion cards except video.
* What was the last thing you did before this started happening?
SOONER
323
I had been having random reboots so it had been having some hard shutdowns. I havent changed any hardware.
MadRat
12,014
321
CONTROL PANEL - SYSTEM - Device Manager
You want to go through each list of devices and eliminate duplicate entries of drivers under each category.
John
MadRat, that was already suggested in the 2nd post, and it didn't help SOONER's problem. :(
MadRat
12,014
321
Actually the other guy suggested removing the top one, not all of them. But whatever.
What you may have is an ACPI issue; they are common when using multiple bus mastering devices. Disable it and try again.
