bryanW1995
- May 22, 2007
- 11,144
- 32
- 91
Same here.Originally posted by: bmwme
[Well I'd love to but I'm encountering wierd problems...either I have two completely different SATA drives with the exact same problem or some wierd motherboard issue with SATA. I first replaced the drive thinking it had failed...same problem. Then I replaced the SATA controller with a PCI one. It worked for a month then same problem. I'm having bad data corruption. Right now I'm posting from said computer but running a PATA drive and everything seems to be ok...
It is just wierd and I don't like it! lol I just want to be able to run my 600gb of SATA hdd's without issue!
I know the ram is ok, I know the cpu is ok, but it just doesn't jive when I'm using SATA. I just want to be done with this motherboard but can't afford to do it right.
Hey how much power would be needed to properly run a dual core CPU like a e2160?
I have a coolermaster 450w...
Use Newegg's Advanced Search and select the relevant parameters.Originally posted by: bmwme
Is there an AMD board that accepts DDR1 and AGP?
Originally posted by: Cogman
Wow, AM2 + AGP motherboards are rarer then I thought. Either way, here is what I came up with.
MSI K9MM-V AM2 VIA K8M800 Micro ATX AMD Motherboard - Retail $47.99
Kingston 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model KVR667D2N5/1G - Retail $24.99
AMD Athlon 64 X2 4000+ Brisbane 2.1GHz Socket AM2 65W Processor Model ADO4000DDBOX - Retail $69.99
Total
142.97
Thats probably the cheapest you will get (unless you go for a sempron), You might think about doubling the ram
Originally posted by: SerpentRoyal
- $71 after rebate Abit IP35-E. P35 board with full 45nm quad (Peryn) support. No problem pushing a capabable Intel CPU north of 3.6GHz.
- $20 after rebate (1GB x 2) HP/Crucrial 1.8V DDR2 667.
- E2160, E2180, E4400, or E4500. Look for sale @ $80 or less. Most will hit 3.2GHz with a few north of 3.4GHz.
$171 total or less. Use the extra $ for a new GPU. You can upgrade to Peryn quad down the road.
This rig can easily hit 3.2GHz if you don't happen to come across a bum CPU.I like this route. You shouldn't have much problem selling your 7800gs, also sell your ddr1 ram, you should have enough $$ to upgrade your GPU a little too.
Hey what would be better...
ASROCK mobo with AGP 7600GS or the evga 630i chipset mobo with onboard nvidia 7100?
Originally posted by: Denithor
If you are gaming at all integrated just won't cut it. Period. Here are some other options (the 8500GT I found is $15 cheaper than the one you are looking at).
EVGA 8500GT $54 after MIR
Leadtek 8600GT $70 after MIR
GeCube x1950pro $111 after MIR
MSI 8600GTS OC $131 after MIR
MSI HD 3850 OC $176
I wouldn't seriously look at the 8600GTS, if you can go that high definitely spend the extra $50 and get the 3850, which is about twice the card for 30% more cash.
Well, if you plan to reuse the video card you get now in an HTPC, go for this passively cooled XFX 8500GT OC that is $65 after MIR. That will be blessedly quiet for the HTPC and should also suit your needs right now for low end gaming.
Consider this for the rest:
Biostar P35D2-A7 $66 after $20MIR
Celeron 420 $43
Kingston 2x1GB DDR2-800 $42 after $10MIR
Antec Earthwatts 500W $35 after $40MIR
I don't know if you can salvage your HDD + optical drive or not but those are easy to find at low cost on newegg/zzf/mwave/etc. Throw it all in a cheap case, overclock that Celeron to ~3GHz and enjoy.
Originally posted by: GundamF91
It does not take AMD to be a budget build.
