Strange red residue left by house water
spidey07
65,469
No idea what this stuff is. It will build up in toilets around the water line and the shower where water may sit. It is easy to remove by scrubbing without cleaners but does take some elbow grease to do so.
But it's the color - a pinkish/red that is puzzling. Could it be bacteria?
I'm thinking about having the water company come out and test my water. We've got pretty good water here and my tap water measures 240 ppm total disolved solids (TDS).
thanks for any guesses/answers.
spidey07
65,469
5 years old. I think all the plumbing is PVC.
I would think mineral stains would be harder to remove?
It's a pretty bright pink, not the rustish red I think iron would leave. don't know though.
BlueWeasel
15,944
475
Well, it's not your piping that's the problem then. The description still seems like excess iron. Do your neighbors have the same issue?
spidey07
65,469
Good point, I'll have to ask them the next time I see them.
Meanwhile I'm probably going to have the water company come out and run a full set of tests.
Anubis
78,712
427
tbqhwy.com
its iron in the water, you can get a filter that takes care of it
if theres too much in it you cant drink it and it turns wiskey green
anyway call your water compant they will come chesk it out
Kaido
Feb 14, 2004
52,123
7,508
Yeah, my brother had this in his old apartment. He said it's hard water, you need a water softener.
bctbct
4,868
sounds like the water mains in your area have rust....no way to fix it without the city changing the main.
MX2
18,651
I get it too:( I am positive its hard water related. My water is so hard you can make rocks with it:(
Queasy
Moderator<br>Console Gaming
Aug 24, 2001
31,796
Might need a water softner. Might also need to flush your water heater and let all the mineral build up in there clear up. Mineral/Sediment build up in your water heater can cause other problems.
