This just started happening a few days ago after my machine had been working fine for weeks.
After having my PC off for a while (more than three hours straight), when I go to turn it back on from a cold boot, my monitor turns itself off when the Welcome screen is supposed to load. After that, the monitor just sits there blinking its LED at me: green, off, green, off, green, off. NOTE: it doesn't give me a "no signal" message, or an "out of range" message -- it just sits there with the LED blinking and displaying no image. In fact, the LED doesn't blink orange like it would if there was no signal -- just green, off, green
In the meantime, the PC is running perfectly in the background -- I can hear RivaTuner load up my fan speeds etc. I can successfully shut down the PC using Alt+F4+U; nothing is freezing or locking up or BSODing.
To get it working again, I have to completely shut the PC down, turn it back on again, switch the DVI port the monitor is plugged into, then turn it back off and on again. Restarts don't work, it has to be a complete shut down or the display won't initialize.
The thing is, once it initializes, it's perfectly fine -- no graphics instability whatsoever. I can game for hours with no problems. In fact, I can even shut the PC completely down, but I can't let it sit for more than a few hours or it'll go back into this problem state.
So yeah, a big WTF from me. Any ideas? My 8800GTX isn't overheating, it's perfectly stable for the month I've had it, and so is the rest of my system. Like I said, when the monitor turns off, nothing is unstable in the background. I'm using the 158.27 WHQL drivers and I've tried reinstalling them two or three times...
Any ideas?
Any ideas?
