- Oct 13, 1999
- 22,377
- 2
- 81
Just wanted to toss this one out here just in case someone else comes across it.
Slowly doing my main rig build, and had problems with my P8P67 Pro. It would POST one time, and then it wouldn't POST again, until I took the CPU out and put it back in.
At first I thought it was my Zalman CNPS10X Flex, because the first time I reseated the CPU I just rested it on the CPU without bolting it down, and it POSTed. So, bolt it down, no POST.
I tried a Cooler Master Hyper 212+, same results. Then, I notice that the VGA LED stays lit when it won't POST (it also does the beeps). So, I try all three PCIe x16 slots, then I try another graphics card (tried a GTX 285 and a GeForce 7300LE). No dice. Was it a bad board?
Nope. Turns out the board didn't like the PNY RAM. I have two 8GB kits. I wanted to use the PNY because it is 1.5v (1333MHz 9-9-9-24) and that's exactly how BIOS detects it, but alas will only POST one time and then the motherboard gives the VGA error.
I tried my other kit, which is Patriot Sector 5 at 1.65v (1600MHz 9-9-9-24) and it POSTs reliably now, though the RAM detects at 1066MHz 7-7-7-20.
Haven't checked, but my guess is that neither kit is on the QVL.
So, my point of this post is that sometimes the problem isn't what you think it is, or what the motherboard claimed it is (VGA problem when it was a memory problem).
Oh yeah, and it really helped to have tested this outside of the case.
