Strange car problem, changed flat using donut, now refuses to move!
flot
3,197
Did you possilbly knock one of the wheel studs back into the wheel? Did you put the donut on inside-out?
0roo0roo
64,795
84
Originally posted by: RagingBITCH
Is the jack still on your car? :p did you put the lugs back on?
yes yes yes! its a shop type jack, hard to miss... or not trip over. and yes lugs and back on. brakes seem standard size, so no rubbing or whatever with the wheel. wheel easily slipped on too.
AaronB
1,214
Originally posted by: Heisenberg
Maybe you put the donut on backwards and it's scraping the brake caliper?
I think this is the most likely culprit, either that or the spare was the incorrect type for the car.
0roo0roo
64,795
84
i thought of that, but the donut will not go on hollow side out. the brake caliper would be in the way. uknow.. donut wheels are kinda shaped like bowls to accomidate the brake assembly.
imported_Phil
9,837
Take the donut off, maybe that'll help.
:p
damonpip
635
Did you get something lodged between the wheel and the brake?
Is it the original donut?
0roo0roo
64,795
84
considering the mods on this car i'm starting to think its nonfactory donut. squish up to a caliper and it would lock the wheel no?
and do front wheel drive front wheels freewheel when jacked up?
Pepsi90919
not if they're in park
flot
3,197
Put the car in neutral (careful to put the ebrake on and blocks around the rear wheels) and you should be able to freely spin it with the wheel off the ground.
If it isn't on backwards, then yeah I'd have to lean towards just plain wrong donut..?
0roo0roo
64,795
84
ok, i'm just sure its nonstandard donut now. i took it off again. look inside, theres a gouge where the caliper pressed up against the inside. ah well. so much for that. beware of nonstandard donuts.
AaronB
1,214
Teh winnar is me!
