strange audio humming noise under certain conditions
quartzz1
50
Hi
I have a strange buzzing noise that sometimes comes from a laptop/subwoofer setup under certain conditions. laptop is a fujitsu lifebook a531, sub is this
https://www.amazon.co.uk/Trust-21787-Surround-Speaker-System/dp/B07643GD6Q/ref=sr_1_2
it happens under the following conditions
hum is virtually silent at subwoofer bass dial set to minimum. hum gets louder as subwoofer bass dial is turned up to halfway, hum dies down to almost nothing as sub bass dial goes to maximum
hum is made worse when an hdmi cable (2 metres long) connected to a TV is plugged into the laptops hdmi port
my gut instinct is that its to do with the laptops internal earthing. educated guess. I've just ordered a new hdmi cable, which should get here in a couple of days. but the hdmi cable I'm using at the moment isn't a cheapy
any ideas welcome..? more info can be given
The sub is still under 30 day trial so I can send it back for a replacement
UsandThem
16,068
7,383
Do you have other speakers that you can test? If so, and they don't display the same issues, it's likely the problem is with your new speakers (which I've never even heard of before).
In fact, since you've been here, I have not recognized any the companies you have linked to on Ebay or Amazon. Maybe it would be less headaches for you going with known brands? Just a suggestion.....
Reactions: corkyg
corkyg
Elite Member | Peripherals
27,370
239
Welcome to the mysterious world of EMI.
quartzz1
50
thanks Usandthem, I'm going to try a 30 day replacement sub see if the same thing happens
Isnt it corky...the same thing happens on a different laptop, so either both laptops have the same earthing...thing....or its not that. I've also ordered a vga to hdmi converter, to see if it happens when the vga, instead of hdmi is used
