- May 22, 2011
- 1,292
- 5
- 81
Ok, I just finished building my new water loop, and it includes
I5 2500k, Asrock Extreme 3 Gen3,7970 XFX BEDD with EK waterblock
I had the CPU under water in the same motherboard with the same 7970, The 7970 was on air before I added the waterblock and it worked flawlessly. I finished up my build and bled the loop. Turn on the system and get a Dr Debug 62 error. I read around on google and try pulling the GPU out of the PCI slot and booting on IGP. It works. I read into it a bit more, and go into the bios and select IGP as primary GPU instead of PCI Express. Put the 7970 back in the slot, and it boots just fine. I cant see the bios at startup, but everything else works. EXCEPT.. Now I have lost the ability to adjust voltage on my 7970 and its got me going nuts. This is why I built the loop, to overclock things. Does anyone have a suggestion to why it is doing this ? Maybe it errors due to no fan being plugged into the GPU?
