I just installed a VF700 cooler on my 6800 Ultra yesterday. I currently get idle temps of ~60C and load temps of about 75C. Rthdribl runs fine and Aquamark gives me about 68k, which is basically the same as what I got with the stock cooler. However, when I play games such as Need for Speed Underground 2 and World of Warcraft, after a few minutes they will freeze solid (requiring a restart) and often show serious picture corruption. What might be causing this and how can I fix it. This is not a problem when I use the stock cooler; after I put the stock cooler back on everything runs fine, the only difference being that load temps are about 85C.
UPDATE: I removed two of my hard drives and now everything runs fine. It seems that my Antec TruePower 380 just wasn't enough juice. Guess I'm getting a 550 tomorrow.
UPDATE 2: While things ran fine at first without the two hard drives, the same problems returned a few hours later. The next thing I'm going to try is adding a case fan. Any recommendations on which brand/type I should be looking for?
