CADsortaGUY
OK - It seems that once again my results aren't getting submitted/counted. The stats site says 56 but my client says 147. It has been running with the same setting since my last post about troubles. So if anyone can point me to ALL the files I need and how to config I'd be greatful.
-Win2k
-permenant connection
-would like to see what is going on(since i've had problems😛)
Thanks
CADkindaGUY
BTW - joinT - I tried installing last night for you but something was messed up so I'll try to reinstall at noon provided I get my current problem resolved(so I don't screw your install up😉 --I'll run it on another machine for a while to make up for the delayed start😱)
-Win2k
Thanks
CADkindaGUY
