Sticky key on remote control
Status
Not open for further replies.
Muse
40,915
10,228
I have a pretty high end (expensive and full featured) programmable universal remote, the Home Theater Master MX-700 and the advance button ( >> ) has gotten sticky. It still works, it just feels funny (pops up a bit slow). Granted, it's probably the single button I have used the most! I figure the contact has gotten gunked up, but maybe it's worn out in some way. I've had marginal success in the past dealing with button problems with remotes and before I spray or apply any kind of liquid to this I want to research the topic so I don't make matters worse. My TV's remote, for instance, has gotten to the point where a few buttons are all but useless or completely dead. Whatever solutions I sprayed or dabbed on them failed to revive the keys Thanks for advice, insights, recommendations, etc.
se7en
2,303
I read nothing in this post but the title alone made me lulz
6/10 without reading anything inside the thread.
Goosemaster
48,775
solution: start watching porn at your computer instead.
I guess it depends on what type of mechanism they use with regards to cleaning. Google your remote.
Muse
40,915
10,228
OK, then buzz off.
dbk
17,685
10
Can't you open it up and clean them individually. I'm not at all familiar with that universal remote, btw.
Goosemaster
48,775
Depending on the mechanism some of the plastic springs are a PITA to get back in.
Muse
40,915
10,228
Yeah, I opened one device and lost one of the parts to a button, so now that button is inoperative. That approach can be tricky.
Goosemaster
48,775
I hate when that crap happens :p
Muse
40,915
10,228
In this case I have workarounds. It's the 9 key on a count-down timer. If I want 9 minutes I can key in 8 minutes and 60 seconds, no biggie. Still I wished I could have found that little red thingie. It just jumped and hid somewhere.
Raduque
13,140
138
I would get a big tupperware container and a large bottle of alcohol. Swish the remote vigorously in the alcohol while pressing the button repeatedly. Should clean it right up, the alcohol is non-conductive and will evaporate quickly.
Status
