Throckmorton
Originally posted by: Rubycon
Originally posted by: error8
It doesn't matter what screen resolution I use, or what settings, because the performance is the same. I don't know what you experience, but I have this severe stuttering all the time, even though fraps is showing between 30 to 60 fps. There is a thread on the NFS pro street forum about this situation, but there is no fix for it. 🙁
It was just slow at 1920x1200 with everything turned on so I started turning eye candy off to make it acceptable. I force V sync off for that reason as it tends to make things stutter. Perhaps that's what is happening on your system?
If you two have stuttering problems, try running Rivatuner, and monitor how much video RAM your game is using. If it's maxed out, that means it has to swap textures with system RAM, which causes stuttering. I'm going to do a lot of tests once I get my 1gb 8800GT because I'm interested in this texture swapping thing that most people ignore. You can still get high average framerates and therefore good benchmark scores, yet have stuttering, because the stutter doesn't last long.
Edit: Wait, I just realized I get that stuttering without a drop in framerate too. Hmmm....
