- Jun 12, 2001
- 8,757
- 43
- 91
Hell ya!!!
THE SHORTEST DISTANCE BETWEEN TWO POINTS IS STRAIGHT ONLINE!
Beginning February 5, 2004, Southwest Airlines is introducing
Online Checkin systemwide, which means you can get your
boarding pass before you leave the house. All it takes is a
Ticketless reservation, access to the Internet, and a printer.
You can start checking in at 12:01 a.m. local time the day of
travel. As always, boarding passes will be distributed on a
first-come, first-served basis. Once you print your boarding
pass, simply go through the Security Checkpoint to your
Departure Gate.* Please note that you will not be able to
check in at southwest.com(R) if you have multiple passengers
on the same reservation.
Should you need to change your reservation after you print
your boarding pass, go to the Travel Center at southwest.com
and cancel your boarding pass. Then change your reservation
and print a new boarding pass. If your travel includes
connections, you must pick up your boarding pass for your
connecting flight at the Departure Gate in your connecting
city. Also, note that while Online Checkin means you miss the
lines, it's still important to be on time as reservations and
boarding passes are cancelled ten minutes prior to flight time
if you are not in the gate area ready to board.
Imagine going through checkin while you quietly sip coffee
in your pajamas. Or spending those few extra minutes at the
office instead of standing in line. Flying faster doesn't
get any better than this. For Online Checkin, please visit:
( http://www.southwest.com/travel_center/retrieveCheckinDoc.html )
We hope to have you online and onboard real soon!
Sincerely,
Your Friends at Southwest Airlines
*If you are checking luggage, please proceed to the Skycap
Podium or Ticket Counter prior to passing through the
Security Checkpoint.
Sincerely,
