Stats a la Geoff... **UPDATE 2004-06-04**
GeoffS
11,583
hmmm... TSC would be pretty simple since all I need to do is change the get_stats URLs... the node information would be more of a problem since I'm using a compiled C pgm that shauge from Team Norway gave me that is hard coded to the D2OL stats pages. Lemme see what I can do :)
Geoff
Shame
2,730
Geoff, I would put SOB stats up there next, those guys worked hard and deserve some of your magic... :D
CXGJarrod
139
Geoff: First, thanks again for all the stats. I do have a thought / consideration for your next update. When you change you name you come in as a new member. The production graph shows 2,160 for my first day and then around 110 per day afterward. Is there a way that you can have it not count the first day? Averages are also messed up because of the first big day. Just a suggestion for the next update. Not really a huge issue.
GeoffS
11,583
Jarrod - You're welcome! :) The only stats that I get that has an ID number instead of using the name as either the team or individual identifier is Lifemapper. Unforturnately, for any of the other projects, I can't tell if someone is a new user or simply a name change. I can blow away a day of data for a single user pretty easily. If people know ahead of time (before the daily update on the day that the name is changed) I can make the change in my database so that this doesn't happen. I think I had that posted on the stats main page for a while, but nobody took me up on that offer so I just took it down since it was just taking up space on the page.
Geoff
CXGJarrod
139
Geoff
I am TA_JarrodHammack. If you can blow off the one day of stats easily, then please do. If not, then dont worry about it. I would give you a link to my stats but due to the popularity of your page iI get the following:
"The page cannot be displayed
There are too many people accessing the Web site at this time.
HTTP 403.9 - Access Forbidden: Too many users are connected
Internet Information Services
Technical Information (for support personnel)
Background:
This error can occur if the Web server is busy and cannot process your request due to heavy traffic. "
Seems there are more stat junkies than just me ;)
GeoffS
11,583
Your first day is history!
I'm looking at the server settings for the other problem...
Geoff
GeoffS
11,583
Okay... found a way to increase the max connections from 10 to 40 (this is running on Win2K Pro, not server), so that should ease the pain a bit :) I may just have to figure out how to install Apache... maybe convert the box to Unix! :)
CXGJarrod
139
Geoff
Thanks very much! Your stats make distributed computing much more fun! ;)
Sit back and have a :beer:
GeoffS
11,583
Geoff
Can't... at work at the moment! :)
Coolkid
2,189
Apache is great, I'd be happy to help you install it if need be :)
Confused
14,166
Geoff,
If you can install Apache, (and can get a port 80 address, slightly less important), i'll point TAstats.com at your box :) It will make things MUCH easier ;) If you need a hand setting up Apache, let me know, i've done it quite a few times :)
Garry
Freewolf
9,673
Looks good Geoff. The only thing I see is when you click on a link the graph gives an illegal scale error.
GeoffS
11,583
Yeah... the graph only has one point at this time... that will change after midnight :) I didn't bother coding for that event since it will be rare.
Geoff
Confused
14,166
Great work, Geoff :)
Let me know when you've got an IP addy that doesn't need a specific port :)
Garry
yelo333
990
Excellent, Geoff. This is excellent! It's really nice to have quality stats and not, say, looking at raw data.
