Starting a DIY sous vide cooker project
Sep 12, 2004
16,852
59
86
Put the pump on the inlet side of the heater so that the max temp would be the highest SV setting - probably 165F or so.
It's still a problem. The pumps I can find that are rated for continuous duty and provide the needed flow are ony rated to handle up to 50C max. There are some I have found that are rated higher but they are a bit expensive. Don't want to spend north of 50 bucks on one.
Howard
47,982
11
Unless you happen to scavenge a used lab/commercial pump, I don't think you're going to get a cheap pump that flows well and is rated for high temps... why not get a cheapie and replace them as they die?
Sep 12, 2004
16,852
59
86
Simple answer - My anal sensibilities won't permit me. :)
Howard
47,982
11
Apparently the auto-tune feature works as advertised; I was getting a steady-state error of 8-10% above set point, but then it dropped to +/- 1% or so after auto-tune. Beats the hell out of manually tuning, I suppose.
This week I'm going to be cutting out the enclosure and tidying up the wiring.
http://pics.bbzzdd.com/users/Yucky/IMG00044-20110515-1443.jpg
Howard
47,982
11
Since I have a big cookout coming up, I think using even a big pot is going to be too limiting, so my plan is to cook the food in a cooler. I already ordered the immersion heater.
Being in Canada, you find that you pay more for stuff than you do in the States...
Howard
47,982
11
Finished up the last couple of things: cleaned up the wiring instead as best I could, calibrated the probe with some boiling water (was off by 2.3F), and swapped the straight-through probe cable fitting (which was super ghetto) with a proper panel-mounted connector, 3-terminal female M8, with a right-angle plug for better impact resistance and durability.
Howard
47,982
11
Hmm. Cool.
I've been wanting to pick up a PID temp controller for my Alton Brown smoker anyway. Damn you! Just what I need, another project... lol.
I got my thermocouple for air temperature last week. I've already soldered it to the quick-disconnect cable and now all I need to do is to calibrate it (see here) and build/find a box for the smoke chamber.
