Paratus
This is light based and not radio wave based?
I know waves are waves are radio waves like 1/100th the speed maybe 1/1000th the speed?
So here’s the basics on satellite internet and what makes SpaceX different along with some physics 101 (feel free to ignore if you know this stuff already)Ah I was under the impression waves for broadcast were in the 500-1000 miles per hours type thing (maybe minute). I thought the super high fast spectrum stuff needed too much power/antenna to be practical.
Thank you for the education.
Satellite internet, like Hughesnet, TV like Direct TV, and Radio like Sirius XM all use a small constellation of large satellites in Geostationary/Geosynchronous orbit.
These orbits are unique in that satellites placed there rotate at the same rate the ground does. So geostationary satellites are always over the same point on the equator. The speed it takes to be at that altitude takes 24 hours to travel one complete circular orbit.
The benefit to this is anyone on the ground who can see the satellite and wants to communicate with the it just needs to point a dish at one point in the sky. From geostationary orbit you can see about 1/3 of the planet.
The downsides are first that to be in geostationary orbit you have to be at 22,300 miles above the Earth. As @repoman0 said all electromagnetic waves travel at the speed of light in a vacuum.
(All of these waves are made of photons and travel at the speed of light. The speed of light is fastest in a vacuum and slower in other mediums)
So @ the speed of light in a vacuum of 186,000 miles per second it takes light a round trip time of 240 milliseconds. That‘s the minimum extra latency added to the other latencies of connecting to the internet. No twitch shooters for those on satellite internet.
Second, those orbits are highly desired and can’t accommodate a large number of satellites. So your 10,000s of customers are sharing bandwidth on just a few satellites.
Finally those satellites are meant to last decades and are very expensive to build and launch. In fact for most of the last several decades it cost more than. $10,000/pound to launch to geostationary orbit.
What SpaceX is doing is leveraging their unique expertise to provide satellite internet comparable to cable and cellular in latency and bandwidth.
To do this they have to lower the altitude of their satellites low earth orbit of about 340 miles. Just a bit above where the ISS operates. This lowers the up/down latency to only 3.65ms plus the other ground latencies to connect to the internet.
The problem is satellites at that altitude orbit the earth in 90-100 minutes. So you won’t be able to point at a single satellite. Ground user will need to continually hand off from one Starlink satellite to another. Plus at that altitude you can only see a much smaller portion of the Earth. To view more users and maintain a connection SpaceX needs a lot more satellites.
Now if it was going to cost $10,000/ pound this would be financially impossible. Iridium satellite phones tried this on a smaller scale in the 90’s and went bankrupt. SpaceX however has drastically lowered the cost to launch LEO and these satellites can be smaller and lighter because they are closer to Earth. In fact SpaceX has fit 60 in a single launch.
Also being in LEO means they will eventually spiral in and burn up in a few years so they don’t have to be built to last as long as geostationary satellites further reducing costs.
Finally with all those satellites (they are approved for 12,000 satellites if I recall) users won’t be sharing as much bandwidth.
It should be possible for SpaceX to provide bandwidth and latencies comparable to average suburban internet for comparable costs.
