- Jun 15, 2002
- 1,165
- 0
- 76
Originally posted by: lmac103
Just ordered one. If you go to weekly specials to locate the drive. you will then be able to order it.
Originally posted by: HumblePie
FOR YOUR INFORMATION!!!!
Please read, big discussion on FW about this and it's CONFIRMED. This is NOT a SATA drive. It's regular IDE. You just get a dual controller card that does SATA or IDE.
Also, SATA cards are worthless because the max transfer rate of the PCI bus is 132 MBs. So putting a 150 MBs SATA card and drive will make it the same speed as any other IDE drive.
Now, if you have a faster PCI bus, then it'll work. Good luck tho.
