dust
- Oct 13, 2008
- 1,328
- 2
- 71
You don't need any mods, but you do need the latest patch, as the faction wars are glitched, sometimes the squads don't follow, or they don't occupy the camps previously cleared by you. Also Freedom is slightly more balanced with Duty, whereas in the previous patches Duty owned Freedom big time.
Another thing to remember is to have manual saves before joining any of the groups and during the assault. You can then join the next neutral faction for a brief moment just to check your real status with the previous enemy faction(e.g. say you are with the bandits and you killed a dozen stalkers, join Freedom briefly and check your status with the stalkers, the idea is to kill as less as possible, not to have them turn hostile to you forever).
Try Bandits, freedom, stalkers, duty.
Bandits are neutral to freedom, enemy to stalkers and Duty. Freedom are neutral to bandits and Stalkers, enemy to Duty(see the pattern?).
The trick is not to kill too many of the opposing faction until you capture their base. Bandits are the least forgiving, usually three kills translates as enemies forever that's why I suggested joining them first.
It also helps your chances a lot if you befriend the future opposing faction to the max prior to attacking them.
