VirtualLarry
- Aug 25, 2001
- 56,587
- 10,227
- 126
rED sQUIRREL ONLY HAS THREE LEFT, PEOPLE ARE SAYING.I made 100 Ks once.
I only have about 10 left, see
KKKKKKKKKK
KKKKKKKKKK
The Bilt card sponsored by Wells Fargo is metal. I have one because I pay my rent with it (basically, the only fee-free way to get credit card points on rent).When I got my updated Chase/Prime CC I did what I always do with old credit cards-I dropped it in my paper shredder. It made a horrible noise and stopped almost immediately. I then figured out the card was metal, and spent about a half hour bending the card, drilling holes in it, hammering it into an unrecognizable piece of scrap.
The next day I noticed the return envelope for sending the old card back to Chase.
BTW this is the only metal card I have-does anyone else have any others?
The premium travel cards tend to be metal these days. Your Amex platinums, chase sapphires, capital one venture x card etc kind of cardsBTW this is the only metal card I have-does anyone else have any others?
I did try that and it was only then that I got to realizing that it wasn't plastic. My tin snips got nowhere. It also resisted my hacksaw blades. That was no go too. It is kind of thick, tough SS under the thin plastic.Use a tin snips if you want to cut it up yourself instead of mailing it back to them. With how thin the SS core is, it should be no problem.
OK... why on earth are they making these out of metals?The premium travel cards tend to be metal these days. Your Amex platinums, chase sapphires, capital one venture x card etc kind of cards
Maybe you need new tin snips. Cut my Prime card up with no issues using them. I don't trust Chase enployees to destroy it.I did try that and it was only then that I got to realizing that it wasn't plastic. My tin snips got nowhere. It also resisted my hacksaw blades. That was no go too. It is kind of thick, tough SS under the thin plastic.
My tin snips ARE cheapo Harbor Freight. But they've never failed me, at least I can't remember them failing. My previous tin snips were seriously cheapo. The HF ones have an engineered leverage system design at least. They are also hefty and handsome. Guess I should keep my eyes open for something quality.Maybe you need new tin snips. Cut my Prime card up with no issues using them. I don't trust Chase enployees to destroy it.
Like I said earlier ....OK... why on earth are they making these out of metals?
Edit: So a simple Google search turned up the following...
Yes, metal credit cards are usually seen as a status symbol because metal card offers are typically geared toward high-spenders with good or excellent credit. Some of the most exclusive credit cards are made of metal, and the weighty feel of the cards certainly speaks to luxury. Metal credit cards have a premium feel.Aug 25, 2023
Status! That is nutty.
And also ...The CC focused Reddit has posters that crave the metal cards as some sort of status symbol. They somehow feel special and important if they have one they can tap on tables to make that certain sound among friends.
Dink, dink, dink .... yeah, that's them.
Or any heat source, even a gas stove flame, maybe even just a flick lighter. All of the information is stored in the strip or chip on the surface and a bit of a flame destroys that.Nobody has propane torches any more?
I have a Bernzomatic TS4000 torch. I have a couple of the blue cans of propane in the garage. I am not a skilled tradesman so the yellow cans (mapp gas) are too pricey for me.Nobody has propane torches any more?
Uh, don't flash your cash... slash?!Guys, guys, you're doing it all wrong. This is how it's done.
I have propane, ran out of Mapp gas. I bought a cheap but recommended oxy-acetylene torch setup off Amazon but don't have a gas setup for it yet. Got it in hopes it could help me fix a bitch of a plumbing problem I had at my kitchen sink during the pandemic.I have a Bernzomatic TS4000 torch. I have a couple of the blue cans of propane in the garage. I am not a skilled tradesman so the yellow cans (mapp gas) are too pricey for me.
I think the AMEX Platinum Card was the first metal card. I could be wrong.
All AMEX cards are centurion cards. The bank behind AMEX is the Centurion Bank which is still AMEX. The black card is probably the card you are referring to. If it was ever called the Centurion card it was not for long. It was impossible to get. You had to be an AMEX customer for more than 10 years and it was invitation only. I guess 2017 is when AMEX made the Platinum card metal. The Black Card has been metal since 1999. The Chase Sapphire Preferred card was introduced in 2009. I am not sure if it was metal in 2009.I think it was the Centurion. The platinum was still plastic when the chase Sapphire Preferred was first launched. The Preferred was metal and the card that really started the shift because it was open to a lot more of the population
Uh no. But don't take my word for it. Take American Express':All AMEX cards are centurion cards. The bank behind AMEX is the Centurion Bank which is still AMEX. The black card is probably the card you are referring to. If it was ever called the Centurion card it was not for long. It was impossible to get. You had to be an AMEX customer for more than 10 years and it was invitation only. I guess 2017 is when AMEX made the Platinum card metal. The Black Card has been metal since 1999. The Chase Sapphire Preferred card was introduced in 2009. I am not sure if it was metal in 2009.
Other card companies have really upped their game in the last 10 or 15 years.
I am confused by your post. The AMEX Platinum card has been around since the 80's. It went from plastic to metal in 2017. Now even the Gold Card is a metal card.Uh no. But don't take my word for it. Take American Express':
You'll notice the trademarked name is "The Platinum Card®"The Platinum Card® | American Express
Earn 5X Membership Rewards® points on Flights booked through AmexTravel.com, on up to $500K in purchases per calendar year. Enjoy benefits across travel, entertainment, and dining. Terms Apply.www.americanexpress.com
And here is some official branding material of the Centurion Card card where they call it "The Centurion® Car
You said "The black card is probably the card you are referring to. If it was ever called the Centurion card it was not for long. "I am confused by your post. The AMEX Platinum card has been around since the 80's. It went from plastic to metal in 2017. Now even the Gold Card is a metal card.
If you want to use them all up, I've got just the song for you.I made 100 Ks once.
KKKKKKKKKK
